Clints LH Project
#126 _Viper_
Posted 27 June 2011 - 07:19 PM
Carpet took the longest... abit of persuasion with the heat gun and trimming and it ended up fitting pretty good.
Seats in, im only a lil fella and the front seats and pretty snug on me, feel sorry for anyone big getting in the front.
Plenty of room in the back tho.
Bad pic as I ran out of light but I Trimmed the surround for the shifter and it looks neat enough for now (will be making a custom full length center console eventually)
#127 _Liam_
Posted 28 June 2011 - 06:12 PM
#128 _Viper_
Posted 03 July 2011 - 05:03 PM
Mostly little things like fit Kick panels, seals behind tail-lights, fitting missing bolts/screws to various places, painted and fit the little vents that go just behind the back doors, Changed my bonnet cable routing so it opens easier, Fuel pump earth wire, Battery isolator switch etc
Was checking the dash and found I had my indicators wired wrong way around (left was right) but that was a easy fix... Dash looks pretty cool all lit up.
Battery Isolator
The Stock SLR door trims were lookin a little tired, tried to give em a clean up but were faded and all the chrome had come off the stripe down the middle so I just gave them a coat of paint for now. Will probly make up some custom trims in the future But at least they look neat for now.
My next break im hoping to get it booked in to have the motor fired up for the first time and run in on the Dyno
#129 _Liam_
Posted 04 July 2011 - 10:03 AM
#130 _Viper_
Posted 31 July 2011 - 11:11 AM
"Psycho" from Billet specialties with a black leather half wrap
was a bloody mixup with the order tho and my Horn button didn't come... I still need to get a boss kit for it too
Had all the scuff strips re-chromed, not the best pic as it was dark
Billet specialties "Flame" mirror, ended up using a Sikaflex Adhesive to glue it to the window... Hopefully its strong enough. It feels solid but only time will tell I guess
Flame radiator cap and 2"x13" Overflow bottle, just need to get some hose to connect it up
#131
Posted 31 July 2011 - 12:23 PM
Wish i had that sort of room behind the grille... between the intake "snorkel" and transmission cooler, its pretty tight in there haha
#132
Posted 31 July 2011 - 02:39 PM
Where about did you get the radiator over flow from?
Ev
#133 _Viper_
Posted 31 July 2011 - 05:38 PM
Billet Works in Malaga also do one quite similar but this one's cap matched my radiator cap and I liked the mounts better.
#134 _gen3torrie_
Posted 31 July 2011 - 08:32 PM
#135 _Viper_
Posted 10 September 2011 - 12:27 AM
Got all new tyres but was still having issues with the fronts touching the flares.
The flare seemed twisted inwards a little but could easily be pulled out by hand, just needed to figure out a way to hold it like that.
Ended up making these bars that bolt to the bumper bar mounts and push it out nicely.
In doing that I noticed the fit of the front spoiler wasnt the best (after I paid to have it all fit professionally)
I pulled out the 2 bolts and the spoiler could easily be pushed up to be parallel with the bumper and sit nicer with the flare, just drilled 2 new holes and is much better.
Tyres were also juuuuust touching on the rear at full lock on the panel join... I forgot to get a pic of it trimmed but I basically cut it back just short of the spot welds and gave plenty of room
Was also having issues with my steering, which was odd as almost everything is brand new and the rack reconditioned... Decided to just pull the rack out and get it checked out... but in doing so I discovered 1 of the cotter pins was loose and allowing some play and the uni joint had some play in it also, so will get a new one of those and new cotters all round... Man was a mission to get all those cotters out with the V8 in there
#136 _Viper_
Posted 17 October 2011 - 02:14 PM
Took the car back to Dave at Extreme Performance engines so he can fire the engine up for the first time and run the cam in etc so by next break the car should be drivable (a wheel alignment would probably be a good idea)
And since It was dust free for the first time in a long time and threads are boring without pics, altho was abit cramped to get some decent shots.
Here's hoping for 350rwhp+
#137
Posted 17 October 2011 - 03:28 PM
Hope to see it in the flesh one day.
#138
Posted 17 October 2011 - 04:44 PM
But pinch a good manual console out of one for me first... for the Dat
#139
Posted 21 October 2011 - 10:30 AM
#140 _Viper_
Posted 21 October 2011 - 11:56 AM
#141 _Viper_
Posted 09 December 2011 - 08:04 AM
In Margaret river untill the 20th tho so wont be picking it up till then.
#142
Posted 09 December 2011 - 10:02 AM
Dealer plates
Its no trouble really.... hahaha
Kidding mate... hope it gets rego and driving soon... Big Als is coming up Feb 11
#143 _Viper_
Posted 09 December 2011 - 07:01 PM
Crap thing is the 2nd hand 650 holley I bought turned out to be shit and he had nothing but trouble with it, and rather waste too much time with it while the dyno was on hire he grabbed one of his spare carbys.
So im not going to have a working carby so wont be able to drive it? Anyone got a good (came off a good running engine) carby for sale?
Edited by Viper, 09 December 2011 - 07:06 PM.
#144
Posted 09 December 2011 - 07:22 PM
#145 _Viper_
Posted 09 December 2011 - 08:30 PM
#146 _Bomber Watson_
Posted 09 December 2011 - 08:52 PM
Summit is your friend.
Unless the body itself is rooted, stripped threads warped baseplate etc, i'd be working with what you have.
Posted 09 December 2011 - 09:01 PM
#148 _Viper_
Posted 09 December 2011 - 10:10 PM
Carby is leaking fuel from the back bowl thru the metering plate some how, cant say I’ve seen it before, so it is always running rich from the leak. It can be started and driven but it runs a bit crappy. It seems like every time it starts it fills the back bowl back up and then when it’s shut off it slowly empties it into the motor, so at start up it’s flooded. Also needs a new Vacuum secondary diaphragm as it leaks air and the secondaries won’t open, so it’s really just a two barrel carby
I paid $200 for this one, I actually dont know too much about carbies... Ive pulled a few apart gave em a clean and put them back together but not even sure which part is the metering plate? altho I do know what the secondary diaphram is..
#149 _Liam_
Posted 09 December 2011 - 10:23 PM
Edited by LX Torry Freak, 09 December 2011 - 10:32 PM.
#150 _Liam_
Posted 09 December 2011 - 10:34 PM
