Clints LH Project
#101 _Viper_
Posted 13 January 2011 - 01:26 PM
#102 _Viper_
Posted 27 January 2011 - 08:39 PM
Just used a few self tappers to mark the holes and see what it looks like
But I think I will upholster it like a Door trim with the hidden plastic plugs on the rear and keep it all smooth. But what color, Black or blue hmm
#103
Posted 27 January 2011 - 09:01 PM
#104 _Viper_
Posted 20 April 2011 - 02:25 PM
Picked up some universal seat rails today also so will get stuck into fitting the seats today or maybe tomorrow.
Edited by Viper, 20 April 2011 - 02:27 PM.
#105 _Kush_
Posted 20 April 2011 - 02:31 PM
That looks noice
#106 _Viper_
Posted 21 April 2011 - 01:21 PM
Gonna have some chow then make a start on the second one and Finally Torana will have seats for first time in 6 years (I like these little milestones)
#107 _Viper_
Posted 21 April 2011 - 05:55 PM
Still goto finish off some wiring, fit the carpet, sort handbrake cable, Give the other pieces of the dash a coat of Satin black, sort Door trims, Make a Parcel Shelf, Seat belts are probly a good idea too!
#108 _Bomber Watson_
Posted 21 April 2011 - 09:09 PM
Blue seats are in the same ballpark.
Good job overall and a few ideas for me to steal.
#109 _Kush_
Posted 21 April 2011 - 09:14 PM
#110 _Viper_
Posted 08 June 2011 - 11:04 PM
I made up a pretty basic parcel shelf and thought Id do a quick writeup as the same process can be used to make door trims or whatever.
I dont have pics of this part as I actually did it awhile ago... But I used some Thin single ply cardboard and made up a template with that first then cut out a backing board from some 3mm MDF... I cut it slightly bigger then multiple times test fit and trimmed slightly then test fitted again etc till I was happy.
Here is a pic of the Backing board and the 2mm Closed cell foam I used as underlay under the Vinyl
I laid the board over the foam and marked around it then used some quick grip on both the board and the Foam, let it dry till tacky then placed the board over the Foam, starting at one end and pushing it down to the other to try avoid air bubbles.
I basically just pour abit of the kwik grip out then use that plastic spatula to spread it out evenly.
Then I just cut all the excess foam off.
I then layed the parcel shelf over my Vinyl and drew a outline around it, removed the board and started applying some more quick-grip.... Because both the Vinyl and the Foam is porous I only applied the Kwikgrip to the Vinyl.
Then laid the board onto the Vinyl in the same way, flexing it so I could start at one end and push it down across to the other... You only get one chance with this stuff, once its down its staying down, if you try to pull it apart it will just tear the foam.
I then marked about 20mm around the board and cut it out.
You can see I didnt cut off the section towards the front that goes up against the seats... Thats because you can just leave the vinyl to hang down over the rear firewall under the seats and there is no chance of it leaving a gap.
I then Folded the vinyl over on the inside and marked where it would finish up so I knew where to put my glue.
Then I put glue on both the board up to where I marked and the underside of the vinyl and let it dry till tacky Then fold it over while also pulling some tension on it so its nice and tight on the other side.
You can see on the corners if you try to fold it over it doesnt quite work out.
So you just have to cut the corners strategically so it will fold over nicely...
Is more then one way to do it.
But as long as it turns out with nothing showing on the top side
The long broard curve along the top is gentle enough the Vinyl can just stretch and conform to shape.... Glue the rest of the edges and your done.
So there you have it a very basic and simple way to trim pretty much anything. You can easily cut out another layer of foam to any shape you want and put on top of the first layer of foam and then cover both layers with Vinyl and you end up with a nice embossed effect, its just abit tricky to get it into all the tight corners...
Here is a couple of pics of some Door trims I did on my Gemini using the same method
I'll get some pics of it fitted to the car when im home next.
Edited by Viper, 08 June 2011 - 11:15 PM.
#111 _Quagmire_
Posted 08 June 2011 - 11:16 PM
looks kinda tricky with those flames
did you mark out and cut any holes in the parcel shelf for the seat belts?
or can this be done later?
#112 _Viper_
Posted 08 June 2011 - 11:27 PM
There is seatbelt mounts in the parcel shelf? lol oops... I bought my car as a bare shell and to be honest have not had a complete Torana for like 6 years... I assumed the seat belts mounted on the C-pillar like my Gemini hehe. But thats ok the Hole can be drilled later without a problem... Just goto make sure you cut the foam and vinyl with a Stanley knife first.. If ya go straight at it with the drill it can sometimes get caught up and rip a hole alot bigger then you wanted.
#113 _Viper_
Posted 11 June 2011 - 05:02 PM
Anyway couple of pics with it fitted, Ignore the rear window thats in need of a re-tint
#114 _Quagmire_
Posted 11 June 2011 - 05:14 PM
my bad then just assumed they where....like the h series etc
#115 _Viper_
Posted 11 June 2011 - 06:09 PM
#116 _Kush_
Posted 11 June 2011 - 06:26 PM
What's wrong with all of you??
#117 _Viper_
Posted 11 June 2011 - 07:08 PM
#118
Posted 11 June 2011 - 07:30 PM
#119 _A9XOSS_
Posted 11 June 2011 - 07:42 PM
which is a pain in the a@#, just spay orange citrus cleaner on it and wait for a few moments. then it will go all gooey / jelly like, it will scrap it off easy as. then clean up with window cleaner and all will be like new again.
Edited by A9XOSS, 11 June 2011 - 07:45 PM.
#120 _A9XOSS_
Posted 11 June 2011 - 07:45 PM
#121
Posted 11 June 2011 - 09:00 PM
#122 _Viper_
Posted 26 June 2011 - 08:08 PM
Also got a new indicator housing (coffee pot) from a HZ ute, which has the stalk with indicators, wipers n washer built in and even Hazard lights so gave that a coat of black and wired it all in and fitted it... Only to find the ignition barrel wouldnt turn (hmm turned fine when it was out of the car). After abit of looking and pulling it off then back on then off found it was Just fowling a little bit on the inner shaft of the steering column in one spot so cut that off and all good. Too bad my brand new Torana ignition barrel doesnt fit it :(
So bolted all the dash in properly. Still need to get a head unit and put a ciggy lighter fitting where the wiper switch used to be... Donno what ill put in the old choke spot?
Then fit the carpet underlay.... which was REALLY a kent to cut... I got some half decent upholstery scissors but yeh... got through it tho.
(have neated it a little more and cut all the holes out for the seat mounts etc since that pic too.
Was getting dark so I quickly threw the "Moulded" carpet in but wasnt a great fit but ill have to wait till tomorrow to play with that. Then chuck the seats in and then the cars pretty much ready to be put on the dyno.
Oh few small jobs to do, some vaccume hoses, earth lead meh im sure ill find more stuff
#123
Posted 26 June 2011 - 08:55 PM
Uni Paint Marker 1.2 mm
Uni Paint Marker 2.8 mm
Edited by ls2lxhatch, 26 June 2011 - 08:56 PM.
#124 _Viper_
Posted 26 June 2011 - 09:02 PM
But either way its obviously not a original resto so whatever color looks good will be the go.
#125
Posted 26 June 2011 - 11:07 PM
This is a restored dash done by dash original. They have used the silver paint.
