Clints LH Project
#176 _2wild4u_
Posted 04 June 2012 - 11:24 PM
#177 _Viper_
Posted 05 June 2012 - 12:12 AM
#178
Posted 05 June 2012 - 12:52 PM
Just a quick one from my gas experience in the 4x4 being 500km from sweet frOck all, the plastic coolant angles love to come lose or break, I modified some washers and slipped them over to get more surface area on the screws that hold them in. Especially seeing you have that curve on the hose.
#179 _Viper_
Posted 05 June 2012 - 01:58 PM
#180
Posted 05 June 2012 - 04:09 PM
#181 _Viper_
Posted 05 June 2012 - 05:40 PM
#182 _Viper_
Posted 10 June 2012 - 11:01 PM
#183 _Viper_
Posted 24 June 2012 - 10:52 PM
I Cut the pushrod off a old booster, lucky it was a solid rod so I drilled the center out and tapped it to suit the new booster, adjustable pushrod now
I test fitted the booster and noticed it was on a angle a fair bit... to be honest I never noticed this before with the old booster... Are all toranas like this?
I temporarily put some washers on the passenger side to get it square with the rest of the bay
I have to check to make sure the pedal doesn't bind up or anything since the booster is now at a different angle... Might have to look at using a rose joint?
Also finished fitting all the uh, fittings for one of the LPG converters.
I think ill change the top fitting in the bay to a 45' instead of straight.
Ive started on the passenger side now....
Oh well thats it for now untill next sunday
Edited by Viper, 24 June 2012 - 10:53 PM.
#184
Posted 24 June 2012 - 10:54 PM
Good work Clintoris
#185
Posted 26 June 2012 - 11:11 AM
cut out the webbing between the inlet runners...
like this:
#186 _Viper_
Posted 26 June 2012 - 03:02 PM
#187
Posted 26 June 2012 - 09:58 PM
Why did you put that silly little booster on ?
#188 _Viper_
Posted 27 June 2012 - 12:15 AM
You commented to me when you first did the brakes that the booster/master sits crooked... and thats how they are
Hah that was like 4 years ago? I guess I forgot.
And for extra clearance... Its not the size that matters, but how shiny it is.... Right?
#189
Posted 27 June 2012 - 01:00 AM
I would have personally left the original or even gone the 8"
But I don't expect to be breaking things and need to pull the rocker covers and heads off on a regular basis like you hoons
#190 _Viper_
Posted 27 June 2012 - 09:44 AM
#191
Posted 27 June 2012 - 08:47 PM
I just think they look alittle small and makes the engine bay look funny
But thats just my useless opinion
I could have used that old booster if you hadn't cut the rod off it... grrr
#192 _Viper_
Posted 27 June 2012 - 10:45 PM
I only cut off the rod from that booster because we are planning to use it in my friends Monaro and will need to modify the pushrod anyway... I could have fabricated it from scratch.. but this was much faster.
#193 _Viper_
Posted 07 July 2012 - 08:32 PM
This was how the old lines were run:
My original plan was to use some banjo fittings on the end of the caliper hoses in the stock location and run the line through the small opening and under the chassis rails like so.
But the banjo fitting was too long and although I know I can get shorter ones I couldn't get the brake nut through opening anyway...
Soooo went down to bunnings and grabbed a couple of Stainless Coach bolts, Gave them a quick polish of course.
Fitted where the stock brake hose used to go (one day when I redo the bay Im going to completely smooth the wheel tubs and this new bracket will just be welded to the underside of the tubs)
Also grabbed a right angle bracket from bunnings, trimmed it down to a suitible size, rounded the ends and drilled a couple holes. filed out one of the holes corners to stop the coach bolt from spinning.
Brackets all fitted up:
Then made new brake lines
Oh, also fitted the passenger side LPG converter
Pick up my Intake on monday so ill be able to fit that next weekend
#194 _Viper_
Posted 08 July 2012 - 08:44 PM
Before I touched it, had already been plated before with a flat floor.
lucky for me the plate was only stiched welded in and seam sealed which made it a little easier to cut out.
Test fitted the tank to roughly where I want it.
Once its all done I'll fit a false floor to the boot level with the diff hump,
Found a little bit of rust in the passenger side rail under the seam sealant, cant really see it in the pic but it will need attention
Departure angle... actually going to raise the tank a little higher then this.
Fitted the brackets up to the tank and got it to the right angle.
I'll also be making a fake alloy drop tank cover so it looks like a normal towana
#195 _berro59_
Posted 09 July 2012 - 10:52 AM
I had a VX commodore on lpg. Car used to fly and cost bugger all to run.
#196 _Viper_
Posted 09 July 2012 - 11:04 AM
#197 _Viper_
Posted 07 August 2012 - 10:42 PM
Got the intake manifold back from the ceramic coaters, fitted it up and finished setting up the fuel rails. Just need to give them a polish.
Also finished running the coolant and LPG hoses to the converters
Not too far off now... grabbed a few more fittings from Chris mills on monday. also got one of the billet alternator brackets... fingers crossed it fits on the Torana.
#198 _greenmachine215_
Posted 07 August 2012 - 11:12 PM
I like how you've used the speedflow connectors and feed throughs, how do you go as far as sealing them to keep the road worthys happy, I know the speedflows are an awesome seal as is, but you have to prove all this bullshite to the transport departments.
Good to see things are moving along again.
#199 _Viper_
Posted 07 August 2012 - 11:37 PM
And yea is no real sign that its LPG except the slightly different looking injectors and extra hoses altho they are hidden as much as possible.
#200 _mumbo_
Posted 08 August 2012 - 09:42 AM
