the fact is i nearly cooked the car back a few months ago, I must have bumped one of the heater hoses loose when replacing the extractors, and anyways the next day when driving the heater hose came almost all the way off, emptied the cooling system, the tempreture guage went off the clock, without me noticing, and the car got so hot it blew the top of the tempreture sender. Ever since then the car has run hot,
Steve
what size radiator you running, and need i remind you of this /\ .
All i know is it is the standard sized radiator for a LJ, so i dunno 2 core maybe?
So you think maybe when i cooked it i have wreaked the radiator?
Steve, temp senders can also suffer from overheating giving inaccurate guage readings. I have read your PM and will call. After reading your post about "its fixed" I thought well good! But about an hour or so later I was out in the shed cleaning up and daydreaming and thought to myself, self? He hasn't driven it yet though. If the guage sender (just so happens there are a couple of them here too) and a rad swap doesn't fix it, it looks like combustion gases getting into the cooling system. You will understand that driving a car under acceleration/load produces more combustion pressure than at idle and may be why it was O.K. initially stationary
I replaced the sender after I nearly cooked the car... i had too, the top was blown off by the heat. Or rather the non metal bit melted and the spring inside pushed the top off. So i doubt it is the sender sending false readings.
By saying gases are leaking into cooling system are you suggesting blown headgasket? And how would i test that?
DA i didn't test the new thermostate in the saucepan before i installed it, but i definately noticed it opening when the car was running. I held onto the top of the thermostate housing and top hose untill it suddenly got really hot, which i assume was the thermostate opening. The tempreture gauge also droped quite noticablely when this occured.
The top hose and bottom hose are still hardly and different tempreture wise, so i would nearly assume the water pump is ok.
ALX76, yes the cap is holding preassure, and yes i have an overflow system fitted.
I might have a go at tuning the car ignition timing wise today. I can't really do much with the fuel/air without taking it to the gas place.
Which would cause a car to overheat, too much advanced or too much retarded on the ignition?
Steve
Edited by 73LJWhiteSL, 06 December 2006 - 10:22 AM.
