thanks for that Kush i wasnt sure if i should have done a double weld or not, but i do now
i also seen a thread to leave a bit on each side so it dont lift but, i think i will chop the lot and clamp it cause im pretty good at getting warpage
so if i clamp each side in a few different spots i should be right ( i hope )
im not to sure if you deoxodine and use POR15 but pretty sure you could apply some cavitiy wax on top to seal the prick right up
on this repair ( the one i avoided ) i made sure i sealed it up good and proper as i didnt wanna have to do it again in 5yrs
i used deoxodine, etch primer, seam sealer, primer, GMH Black, then cavitiy wax, maybe a bit of over kill
but i hope i dont have to do it again
cant wait to see some pic's of you rail chop and to see how you go with the copper backing on the gaurds
Edited by nial8r, 01 June 2011 - 07:09 PM.
