TOY-202
303 replies to this topic
#226 _Bomber Watson_
Posted 03 January 2014 - 03:40 PM
THere not even good as a boat anchor, block is to light.
Totally useless.
#227 _LS1 Taxi_
_LS1 Taxi_
Posted 03 January 2014 - 05:28 PM
LOL, its your thread so you can say what you like....even if it is total shit. :D
#228 _Bomber Watson_
Posted 03 January 2014 - 05:57 PM
Uhu, and you remember that.
#229 _Gunmetal LH_
_Gunmetal LH_
Posted 03 January 2014 - 06:26 PM
So is that grenade engine still about...
#230 _Bomber Watson_
Posted 03 January 2014 - 06:36 PM
Yep.
#231 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 03 January 2014 - 08:11 PM
Turbo
Yep.
:clap:
#232 _Bomber Watson_
Posted 03 January 2014 - 09:48 PM
No.
#233 Potta
Posted 04 January 2014 - 01:47 AM
You know you want to
#234 _Bomber Watson_
Posted 04 January 2014 - 08:24 AM
Its amazing how little i do want to.
That engine may wind up in the uc.
#235 _Lazarus_
_Lazarus_
Posted 04 January 2014 - 09:15 AM
Now you're talking.
During wind tunnel testing in the late 70s it was found that the UC body shape can handle speeds in excess of Mach 2 no problem.
#236 _Bomber Watson_
Posted 04 January 2014 - 09:18 AM
Yep, so sleek and beautiful.
Pity they inly came from the factory capable of mach 1.5.
#237 _Bomber Watson_
Posted 14 April 2014 - 07:11 PM
Right, boring update without picks.
Something is happening again.  I"ve been broke, brought a new race car (Mindi) and been more broke, so not much, but something.
Complete assessment of damage.
Head is non serviceable. All of the chambers have been hogged to far. If we try to weld the issue up then it may just go again.
Good only for parts. 4k down the drain.
As of tonight, a new head has been purchased, a 149 high comp with a bit of tickling already, center posts taken out with crush tubes fitted and the like, but reasonably untouched where its important.
Basically its exactly what i was chasing for a new core. And i assure you, i've been searching high and low.
I havnt seen it in person yet, and wont for a while, as its getting dropped straight to Predator Race Engines in brissy, where Greens Nice (Kev) off these here forums works for him to diddle its skittle.
Will pilfer the paperweight head for parts then probably bansdaw it or put it on the shelf of horsepower or something.
Other damage is minor. 3 and 4 cylinders copped a nice bath, hence need a hone, so i'll get that done at some stage. Should clean up without needing a new overbore.
Will probably throw it a new set of rings as well.
Also i degreed the cam up properly, need to discuss the results with a few more knowlegables but its got 260 @ .050" on the intake, so a bit bigger than i thought. Strangly the exhaust has a touch less duration and lift, so thinking about getting 1.6:1 rockers for the exhaust.  Also just looking at the results with my relatively newby eye i recon it could do with advancing a few degrees. Have adjustable timing gears on it so thats no big issue.
Apart from that its just sitting around fingering my bum waiting for funds to roll in.
Working on other things atm so have hardly looked at the car.
I have picked up and fitted a set of Rare Spares quarter vent seals, as i was never happy with the Betta Auto ones, with good results, i'll start a new thread on that direct comparison once i compile my pictures and thoughts.
#238 N/A-PWR
  • 9,639 posts
Posted 14 April 2014 - 07:28 PM
Excellent Update DJ,
I have read, that Higher Compression needs less Exhaust, as the Pressure Dissipates Quickly,
 so don't change the Exhaust Yet Mate. Dave I
#239 _Bomber Watson_
Posted 14 April 2014 - 07:31 PM
Compression will still be on the low side, Depending on what kev winds up with around 10.5-11:1. About a point or a point and a half lower than where i should be with this cam.
Also the extractors are a little on the small side, and only running a 2 1/2" exhaust, which is borderlien to small for this combo as well.
But yeah, we will see.
At the end of the day rockers are easy to change.
#240 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 14 April 2014 - 07:45 PM
Don't ditch the old head...maybe use it oneday on a meth grenade with no water in it.
#241 _Bomber Watson_
Posted 14 April 2014 - 07:51 PM
Good call Craig. Just fill it with grout.
#242 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 14 April 2014 - 09:31 PM
good to see your not totally over it Bomber.
and the better auto rubber door seals are pretty average too
#243 _to4turbo_
_to4turbo_
Posted 14 April 2014 - 10:00 PM
exactly,the betta windscreen rubbers dont fit either,they are shit.
#244 _Bomber Watson_
Posted 14 April 2014 - 10:03 PM
THe old windscreen rubbers dont fit, the new ones are fine.
I like the door seals, there not a copy of the original, but they work nicely. Havnt seen the new improved rares ones though.
And yeah, never over it, My poor girl, i've ignored her for months on end so many times now, but she's always there for me.
#245 N/A-PWR
  • 9,639 posts
Posted 15 April 2014 - 02:59 PM
Here you go DJ:-
http://www.gmh-toran...02/#entry112434
I am always checking out NOS, and found your 1.5 inlet and 1.6 exhaust rocker set-up. Dave I
Edited by TORYPOWER, 15 April 2014 - 03:05 PM.
#246 orangeLJ
Posted 15 April 2014 - 07:03 PM
I made a jig for the pipes on my LJ if you want a set :D
#247 _Bomber Watson_
Posted 15 April 2014 - 07:17 PM
Hmmm, were they 1 1/2 or 1 5/8th?
And do they actually work? :P
#248 orangeLJ
Posted 18 April 2014 - 08:42 PM
1 5/8" primary
They are an improved version of the hm9c pipes (slip fit secondary with something similar to a burns 3>1 collector)
Pictures are in A build thread somewhere.
#249 _Bomber Watson_
Posted 18 April 2014 - 08:52 PM
INteresting......
Owmucharethey?
#250 orangeLJ
Posted 18 April 2014 - 08:56 PM
I'll work something out and get back to ya :)
There's nothing weird about your engine is there (winged sump, odd engine mounts etc?)
