how much were the wheel tubs and what guage steel are they
tuff 72 4 door
#151
Posted 31 May 2016 - 12:33 AM
#152
Posted 31 May 2016 - 02:35 PM
Plenty of good stuff happening I see
Sure is Heath .gotta love the big boys toys.i feel like a big kid when the parts rock up
#153
Posted 31 May 2016 - 02:52 PM
Hi mate.not sure on thickness of tubs but john would have correct size.just 1 radiused side 360 are a tad over 300 without the sheet steel to fabricate the tub.i radius is 360 to do both sides.in sizes 30",32",and 36".heres a pic of a mustang john has done so it can giveyou an idea how they look..how much were the wheel tubs and what guage steel are they
Edited by madtoranajzedded, 31 May 2016 - 02:54 PM.
#154
Posted 31 May 2016 - 02:57 PM
Mine will be pretty much the same
#155
Posted 31 May 2016 - 03:30 PM
Look's very neat Maz,
Just like how they came out factory, not.
#156
Posted 31 May 2016 - 04:14 PM
my front xmember brackets will be a tad higher but.
That reminds me im needing the the back seat panel unpicked from from parcel shelf to the floor pretty easy to unpick .. and that panel that runs along floor forthe bottom seat.
if anyone knows or has said parts please pm me ....cheers
Edited by madtoranajzedded, 31 May 2016 - 04:16 PM.
#157
Posted 01 July 2016 - 06:28 PM
Top shock bar,brackets.diff bung & vent.
I think this car is jinxed guys sadly.
Gonzo not doing it now,, yer dont ask..
Im going to keep my mouth shut till time
comes to do it..sooo back on the burner
she goes..again
Edited by madtoranajzedded, 01 July 2016 - 06:29 PM.
#158
Posted 01 July 2016 - 07:44 PM
Those tub walls look awesome, sorry to hear about the further setbacks though.
#159
Posted 20 July 2016 - 02:18 AM
omen,Anyway i'll continue on and just try
and do stuff what i can control for now and
so i decided to buy an mig which has rocked
up today.i need now to purchase sills and
lower guard replacement panels both sides
and give it a go.
I want to purchase my own bottle outright
so I got a quote of 479 bills for e size
bottle 105cm tall.i think he said 90 bucks
after the first fill...does this seem about
right.supagas at brighton dont sell there
bottles nor does boc .theres only couple
Places here that do.my brother pays 220
a yr for his.bugger that.
#160
Posted 20 July 2016 - 08:58 AM
Look forward to seeing your work on the replacement sills, I definitely need to do this aswell.
Gasweld in Sydney list the E size Argon mix at $495 so seems like a reasonable price down that way.
#161
Posted 24 January 2017 - 04:45 PM
absolute zilch to the rana..i have had a play
around with the new mig and shes okay.
Had a go welding up the air vent couple days
ago and decided to weld up the heater hole
today on firewall shelf. Looks like a couple
hair dryers for heater demister will do
Tidied up the lip a little bit and a few
holes here there with more to do..well least
theres been some small progress..cheers
#162
Posted 24 January 2017 - 04:56 PM
#163
_duggan208_
Posted 24 January 2017 - 11:19 PM
Its hard to think that something that mean can be really regoed. All the best and good luck with it.
regards
#164
Posted 25 January 2017 - 02:14 AM
where lip is she needs abit of dolly work
using shrinking hammer.
She's shrunk right on the join.will have
to get one of my bros to help get it
abit straighter,save putting 2-3 mil of bog.
i cant grind right in the corners ,wouldnt know
What i could use ? I thought of buying a
dremmel and use stone wheels but i dont think
They would work.its gotta b something small
to get the weld..
Hey Jon..yeah..im going to try.do everything
possible to get it to pass.the problem is
TAS rta's..anyway 2023 is the date im looking
at to be finished,so i'll go through the
process of what engineer says.
#165
Posted 25 January 2017 - 02:59 PM
and purchased a macleans dremmel.well thats
what i call it 😆 and it has worked great
so far with a 60 grit little wheel.
A nice ugly hole there what had hard rock
type shit gmh used..has any taken off that
Inner guard to firewall thin sheet steel
Joiner for a smoother look in pic below.
Looking underneath it has like a 3-4 mil gap
and tapers off like 2mm
looks too shitty of a job just to put
very thin strip of sheet steel in there
Did you use sikaflex or something like
devcon to join it.thinking about doing it..
_duggan208_
Posted 25 January 2017 - 11:25 PM
Yep, no point rushing it.
regards
#167
Posted 01 March 2017 - 10:21 PM
blaster to rock up.first to do is in the
plenum area epoxy prime paint then spot weld
the scuttle panel on..have abit of a dilemma
seems i dont know what color im going would
you guys paint it satin black,colour of car
or por15 it....cheer maz
#168
Posted 01 March 2017 - 10:31 PM
#169
Posted 02 March 2017 - 12:01 AM
similar but cant decide on a solid or metalic.
I seen this clip of this purple hq monaro?
doing this huge burn and he was cruising too
It was at powercruise you might of seen it
I like that color and the other you have seen
This one looks a solid color the other metalic.
Ive also got to think it cant b hard to paint
as im just a novice..
Edited by madtoranajzedded, 02 March 2017 - 12:04 AM.
#170
Posted 02 March 2017 - 12:16 AM
where did you get the car rotator and how much?Things starting to happen.waiting for the
#171
Posted 02 March 2017 - 01:26 AM
from Altraks.0411202423 .rang him on a Sun
and it rocked up fri.he dont muck about and
great bloke aswell..he has only one left.
Check it out on ebay.will hold 2 ton.im
pretty happy with it.was abit scary at first
When turning..didnt trust my welds lol..
Edited by madtoranajzedded, 02 March 2017 - 01:27 AM.
#172
Posted 02 March 2017 - 05:10 PM
out damaged lower fender section.cut it
95mm down from the lower line..then put old
piece up against the shitola rares just to compare.
It should be okay once i trim..
well it froken wanna be
Edited by madtoranajzedded, 02 March 2017 - 05:15 PM.
#174
Posted 02 March 2017 - 08:51 PM
part.its abit short on the wheel arch side
They are pretty piss poor but what can ya do
Eh?...if anyone else is doing theres there
is a 6-7 mil lip you have to grind down
so the replacement panel sits flat and level
with lower sill.i recommend to leave 3 mill
of the lip because it will b short on other
side that way you can flatten and use it
which i have found out 😠.what i have to do
now is split the lip on arch side and widen
it so its level
#175
Posted 02 March 2017 - 08:57 PM
that the lower fender attaches to.im using a
broom lol to bend it up so i can see how it
looks .it dont look too bad there but inside
Is a little different ..looks like i have to
straighten more
