CHOPPER's Drag Only UC
#76
Posted 19 January 2006 - 06:31 PM
#77
_draglc_
Posted 19 January 2006 - 06:40 PM
#78
_CHOPPER_
Posted 19 January 2006 - 09:39 PM
Back on topic.
Got a couple of brass wheels for my hammer drill from Bunnings tonight. The body sealer/sound deadener/sticky shit is coming off nicely, but is very time consuming. I've cleaned up around the rear screen and have started around the front screen. My concentraion then started to wander and I started wire brushing bits that don't really need it. I then realised I wasn't achieving much, so I have now locked up the garage for the night. My plan is to spend at least 30 minutes out in the garage doing something usefull. That could mean cleaning it up, but I'd prefer to leave that job for Ron. Later on.
#79
Posted 19 January 2006 - 10:19 PM
RACV MAN
#80
_CHOPPER_
Posted 19 January 2006 - 10:22 PM
#81
_TORANASS_
Posted 20 January 2006 - 06:25 AM
i had VR V6 commodore injectors in my VK EFI
Sammy did you need to modify anything for them to fit or were they a strait fit..
My blue 202 was making about 170hp at the flywheel using totally stock VK EFI other than an aftermarket fuel pump
What was done besides the VK EFI and what did you do about Ign as the VK EFI ECU doesnt cater or it, its a fuel only managment..
And even tho you had more fuel pressure at the injectors how did you get the ECU to up the duty cycle so they can thro more fuel. Was the 170HP dyno proven or just a estimate? Im asking as my mates son is puting an EFI 202 in a gemini coupe and his on a small budget(15 years old)..
CHOP whats the go with tranny, you using a trimatic i asume or 4spd? I spose you allready no of the gemini converta histall trick..If you gona run a gemi converta let me know ill give you one, i have a complete trimatic from a gemini in workin order..
John
PS Red goes faster anyway..lol
#82
_torana_
Posted 20 January 2006 - 09:27 AM
seems to work for all the ricers.
plus you could put a 6 inch exhaust tip on it (but it may create a venturi vacum effect at the rear of the car and actually slow it down )
#83
_Sammy_
Posted 20 January 2006 - 09:31 AM
pretty much most commodore injectors that i have seen fit straight in, the injectors look almost identical other than the colour etc ....i had VR V6 commodore injectors in my VK EFI
Sammy did you need to modify anything for them to fit or were they a strait fit..My blue 202 was making about 170hp at the flywheel using totally stock VK EFI other than an aftermarket fuel pump
John
all that was required after fitting the injectors was to adjust the air flow meter to suit the different injectors, i had to lean it out a fair bit, i guess for the same opening time and fuel pressure the VR injectors flow a fair bit more fuel.
the motor has been dyno proven at 132hp at the wheels, when using the 30% drivetrain loss i worked out about 170hp at the flywheel - could be more, could be less, will never know without engine dyno i suppose.
The ignition is sorted with a blue motor electronic dizzy which has been regraphed to suit my motor .... oh and the dyno run was on BP Ultimate in everyday tune.
done other than VK EFI, where do i start .... go to this link, its got all the specs
#84
_TORANASS_
Posted 20 January 2006 - 11:00 AM
Air flow meters are restrictive, a map sensor is much much better. Thats why i like the delco from a VN onwards.. They arnt to hard to regraff and use on a holden six. And you can still use a elec dissy and rid the coil packs. another way would be to machine some sort of plate to bolt to your front balancer and use a crank angle sensor and the CDI coil packs from VN, VP, VR.. That should improve spark and performance on a low budget..
Im just about to buy a kalmaker workshop kit for my hatch.. Now that should be fun and games..
John
Just thought of the EST carby black motors from the VK, they run a crank angle sensor on the back of the head and pick up from the converta or flywheel in a manual..Another solution i gues..
#85
_Sammy_
Posted 20 January 2006 - 01:55 PM
as far as the delco ECU goes, im working on that ... i have welded the flange from a VN V6 TB onto my VK EFI manifold, i have an o2 sensor fitted to the exhaust, next is to work out a crank trigger, the vk est option is out of the question, it only has four sensors on the flywheel, you need alot more to get the accuracy of the VN trigger ....
i also plan to use the VN S2 coil packs, if im going delco its all or nothing
and yeah im hoping once its running right it should be a far less restrictive system and a far more tunable/self learning system unlike the VK EFI which is like a carby as far as tuning goes, once you tune it thats where its set till you re-tune!
i have a VR V6 im fitting into an FB Ute, i plan to run that on a kalmaker i think, so far it looks like the best tool that 'I' can tune and play with ... be #@$^%& if i want to pay shitloads to get someone to do it for me.
#86
_TORANASS_
Posted 20 January 2006 - 03:06 PM
Chop sorry for hijacking your thread, maybe we should start a custom EFI conversion thread in the technical section..
John
#87
_CHOPPER_
Posted 20 January 2006 - 09:25 PM
I'm using a Trimatic. I won't be using the Gemini converter. I tried that once behind an XU-1 spec 202 in my HZ. The converter lasted 8 minutes.CHOP whats the go with tranny, you using a trimatic i asume or 4spd? I spose you allready no of the gemini converta histall trick..If you gona run a gemi converta let me know ill give you one, i have a complete trimatic from a gemini in workin order..
#88
_CHOPPER_
Posted 20 January 2006 - 09:26 PM
That's OK, it makes my project look popular.Chop sorry for hijacking your thread, maybe we should start a custom EFI conversion thread in the technical section..
#89
_TORANASS_
Posted 20 January 2006 - 10:34 PM
LOL well it is intended for a 1600 gemini 4pot..
Altho a mate used a gemini converta once in his LC GTR with a 202 solid cam and 465 4brl holley and it worked fine for quite some time.. maybe the HZ was too heavy for it..My brother works for hollroid engineering in fairfeild, they are a converta place and trailer spareparts.. Ill get him to speek to the guy he works with that does the convertas. he quoted me $200 for a 2500rpm stall for my trimatic.. If you are interested that is?
John
Edited by TORANASS, 20 January 2006 - 10:36 PM.
#90
Posted 20 January 2006 - 10:57 PM
RACV MAN
#91
_CHOPPER_
Posted 20 January 2006 - 11:15 PM
Rear suspension
Front suspension
Steering column
Brakes
THEN
I play with the engine and box.
#92
_CHOPPER_
Posted 23 January 2006 - 06:09 PM
#93
_Swampy_
Posted 23 January 2006 - 07:06 PM
#94
_CHOPPER_
Posted 23 January 2006 - 07:09 PM
#95
_Swampy_
Posted 23 January 2006 - 07:17 PM
#96
_CHOPPER_
Posted 23 January 2006 - 10:02 PM
#97
_CHOPPER_
Posted 26 January 2006 - 08:42 PM
#98
_1SICK6_
Posted 27 January 2006 - 01:15 AM
Edited by 1SICK6, 27 January 2006 - 01:16 AM.
#99
_draglc_
Posted 27 January 2006 - 08:52 AM
Really interested in knowing!
A1
#100
Posted 27 January 2006 - 02:02 PM
