I just had the axles and discs redrilled for HQ.. Easy.
Edited by rorym, 27 October 2007 - 07:44 AM.
Posted 27 October 2007 - 07:44 AM
Posted 27 October 2007 - 07:11 PM
Posted 27 October 2007 - 09:38 PM
Posted 27 October 2007 - 11:28 PM
Posted 01 January 2008 - 05:06 PM
Posted 01 January 2008 - 10:11 PM
Posted 02 January 2008 - 08:18 AM
magna is not the same as ford already looked into that i work at a mistubishi dealership n we have them lying around every were but l300s are the same as falcon stud patternjust cheat and get multi fit (chevy/ford stud pattern) rims, as i believe that skyline stud pattern is the same as ford/magna/chrysler and im sure othersThanx, was wondering if the bearing and bearing/axle retainer plate are the same. Will save me having to respline a commy axle.
cheers adam
Posted 11 January 2008 - 07:39 AM
Posted 18 January 2008 - 06:30 PM
Posted 19 January 2008 - 12:00 PM
Posted 19 January 2008 - 02:19 PM
Posted 19 January 2008 - 04:07 PM
Posted 19 January 2008 - 05:08 PM
Posted 19 January 2008 - 10:43 PM
Posted 19 January 2008 - 10:53 PM
Edited by rorym, 19 January 2008 - 10:57 PM.
Posted 19 January 2008 - 11:00 PM
Posted 19 January 2008 - 11:02 PM
I am not sure this is the case...if you get off it...the teeth do move out slightly...but it a race situation you are off it for 1/2 a sec..then you hit it again so they bite again...I guess trial and error will tell but I am pretty confident from what I have heard it wont disengage far enough under such speed/power.wont the lokka be engaging disengaing through corners if you happen to be on/off the gas for what ever reason? where as the spool is a constant.
Posted 19 January 2008 - 11:40 PM
Thanks Rory, the cash is ready and waiting.When its out...you have first bite Chopper.
Posted 19 January 2008 - 11:47 PM
I don't suppose I'll be getting it that cheap?Simple decision. Sell the full spool to me for $50 and that answers your question and helps me out too.I bought an LSD centre for $80 and a full spool for $165, so I now need to decide what way to go.
Posted 20 January 2008 - 06:12 PM
Posted 20 January 2008 - 06:16 PM
Posted 20 January 2008 - 07:26 PM
Posted 21 January 2008 - 10:34 PM
Good point LS2 but I think it is more orientated to road then full on race?..Being adjustable??...The D/Locker style seems to be the tool of choice for the track...Most guys I talk to seem to think after afew runs you know in your brain what it is going to do....guess its all about experimentaion...(No Heath!!...Not that type!! Get rid of the donkey!)A KAAZ LSD is quite different to a Lokka. The KAAZ uses a cam to increase pressure on the LSD plates. It is available in 1, 1.5 and 2 way designs.
As far as I know the lokka is only one way dog clutch which is either engaged or disengaged.
Edited by rorym, 21 January 2008 - 10:35 PM.
Posted 21 January 2008 - 10:45 PM
Posted 23 January 2008 - 04:35 PM
